Auto transmission fluid capacity
Old 12-04-2006, 08:08 AM
steerjock's Avatar
Well I just had the tranny rebuilt and now its time to fill it back up, but I can't seem to find specs on how much fluid an "empty" tranny should take. Anyone know???
Adam
Old 12-04-2006, 08:57 AM
GearHd6's Avatar
I dropped my valvebody and let it all drain out for a week and it took 12 quarts to fill that up. So I say at least 12 to start.
Old 12-04-2006, 09:48 AM
GearHd6's Avatar
My Chrysler shop manual claims 17.5-33 pints? Seems like a pretty big range to me. Maybe 33 pints is with the converter empty?
Old 12-04-2006, 10:16 AM
b.lee's Avatar
correct, it will take more fluid if the converter is drained.
and that doesnt happen when you just pull the pan off.
Old 12-04-2006, 12:07 PM
steerjock's Avatar
Well everything in my tranny was empty as everything was removed to go have it rebuilt
Old 12-04-2006, 07:14 PM
88bird's Avatar
it took 19.5 quarts to fill my Goerend tranny up.... i have a single deep MagHytech pan....
Old 12-04-2006, 07:20 PM
infidel's Avatar
It's taken me 17 quarts to fill a bone dry tranny with stock pan.
Don't think it's possible to ever get that much in again unless the trans is rebuilt.
Just dropping the pan it takes 4-6 quarts to refill.
As long as the fluid isn't discolored or burnt smelling it's a perfectly acceptable practice to just replace the 4-6 qts of ATF from a pan drop. The ATF itself is usually fine but the additive package may be getting low. The addition of just a few quarts is enough to replenish the additives.
SEABEEDALE
04-15-2008 12:20 PM
LockedandLoaded
01-17-2008 02:51 PM
ouchman
02-25-2006 11:22 AM
orcaburger
10-05-2003 08:40 PM
BuckBoardDriver
07-03-2003 07:30 AM
Quick Reply: Auto transmission fluid capacity
