auto trans shifting trouble
Old 11-28-2011, 01:03 PM
jahagb's Avatar
hello,i have a 98 12v ram 3500 and somtimes when taking off from stops it will shift from 1ST through all gears almost instantly lugging down motor and almost making it die, i can pull it down into 2nd to keep truck running. the truck will keep doing this at every stop untill i stop and shut truck off for awhile. could this be the tps? thanks for any help, also it has been hold low gear before shift ?
Old 11-28-2011, 07:38 PM
green95's Avatar
1.Band adjustment,2.Servo band or linkage malfuntion(ie:,binding linkage,warped band,servo piston stuck.)3.dragging clutch(not releasing fully)4.broken or siezed planetary gears,5.overrunning clutch worn,broken or siezed.(just had my book open at the tranny section for another member).hope this helps you.
Old 11-29-2011, 07:13 AM
j-fox's Avatar
The only thing I come up with that will lug the engine at light throttle is a bad torque converter.
Old 11-29-2011, 08:03 AM
jahagb's Avatar
when it does this u can feel it shift through all the grears in just a few seconds
Old 11-29-2011, 05:30 PM
green95's Avatar
converter clutch could be sticking,how is the cond.of your fluid? maybe a fluid and filter change would reveal something.
Old 11-29-2011, 08:34 PM
jahagb's Avatar
just serviced and replaced gov.pressure soleniod and transducer solenoid.
Old 11-30-2011, 10:26 PM
turfguy's Avatar
if the shift points aren't right I would check the adjustment on your T.V. cable
AlanF
07-25-2007 02:19 AM
Turbobob
16
09-11-2006 07:15 PM
DL1221
08-07-2006 03:06 PM
Dodgezilla
01-23-2005 04:14 PM
Scott_321
09-27-2004 08:37 PM
Quick Reply: auto trans shifting trouble
