auto trans question
auto trans question
Ok so i have been driveing ctd for years but this is my first auto. i am conserned about the shifting. the think shifts great through all the gears but when i turn the od off it seem to only go to 3rd gear rpm 2500 at 60. Push the od button back on it shifts to 4 th then to od. is this normal or is something out of wack?
hi
that sounds right
mine only goes to 3rd with od off but does lock convertor in 3rd then unlocks convertor when i hit the od on button then shifts to 4 th and then lu .
with aditional l u switch i can lock in 3 l u and switch dictrectly to 4 l u
that sounds right
I had the same question when I got mine. Feels like more gears, but TC lockup is what you're feeling. 1st gear, 2nd gear, 3rd gear (if od is off, you will feel TC lockup here like another gear), 4th gear (OD), 4th gear TC lockup. Actually feels like 6 gears if you go to 3rd tc lockup then go to OD, then OD tc lockup.
DodgeDiesel61
06-03-2008 07:50 PM
