auto tranny to standard
Old 09-26-2009, 07:22 AM
39b
39b's Avatar
was wondering if anyone has ever replaced there auto tranny with a standard? How hard was it? I am getting ready to do something with my tranny in my 03 was just trying to figure out what was the best way to go for the money.
Old 09-26-2009, 08:42 AM
Spooler's Avatar
Build the auto up and you will be fine. I would go with a Goerends myself. An auto to manual has many complications and if you don't do a very professional job noboby will want to buy it if sold.
Old 09-26-2009, 07:33 PM
39b
39b's Avatar
thanks for the info where can i get some info about the Georends trannys
Old 09-26-2009, 07:38 PM
hector's Avatar
Here http://www.goerend.com/
Old 09-26-2009, 07:47 PM
larrybartlett's Avatar
I love my Goerend
Old 09-26-2009, 08:48 PM
Spooler's Avatar
I looked at it also and you see what I did. Mucho Better!!!!!
Old 09-27-2009, 05:57 PM
dieseloutlaw1's Avatar
x2 here!!!! I love my Goerend!! Call Dave you won't be disapointed!!!!
Old 09-27-2009, 08:04 PM
Raspy's Avatar
39,
I've been wanting to switch my 48RE to a G56 too. It's a bit of work and expensive with lots of bits and pieces. By the time you consider the bell housing, clutch, pedals, tranny mount, driveshaft, the g56 itself and all the other items it gets expensive. Unless you can find someone with a manual truck that wants an auto and is willing to switch the parts.
I'll be the last one to tell you that building your auto is the way to go. A built auto and a stick are definitely not the same thing. For me, towing and mountain driving would be sweet with a stick. No one can tell you what is right for you.
Because of the extra work and expense, I'll probably rebuild my auto. But it's a compromise and I'm not sure I'll go that route.
Old 09-27-2009, 11:59 PM
Spooler's Avatar
If you gotta have a stick, go and purchase a truck that came from the factory with a stick after you sell the one you have if you have to have one. A built auto is not a stick but much much better then the factory 48re and it is good except for the sloppy converter.
Old 09-28-2009, 02:31 AM
HMX-1's Avatar
I traded in my '03 3500 auto for my '08 3500 6 speed manual for this very reason. The manual will have no issues pulling whatever you need to tow. I couldn't get over 50 MPH in my '03 pulling 6700 pounds; in the new truck the only way I could tell I was hauling something was I needed to take off in first, where normally I use second while running empty.
If you can swing it, I'd recommend the upgrade and get the manual all at once.
Kris
Sittenbull2
07-25-2012 12:34 AM
ezdemon72
07-29-2005 10:05 AM
mamm7215
08-21-2004 08:49 AM
SAWBUCK
11-15-2003 11:02 PM
PurdellMGP
10-16-2003 08:37 PM
Quick Reply: auto tranny to standard
