View Full Version : Auto tranny O/D control ?
DLittle
09-14-2010, 05:21 PM
I'm in the process of putting the engine , transmission and running gear out of my wrecked 93 into my 1973 W100 swb. What I want to know is what's the best way to control o/d on the 518 tranny with out the computer . I would like it to still be automatic and be able to push a button to take it out of o/d ?
Chrisreyn
09-14-2010, 05:35 PM
Do the POT install... the OD button will still work, and its set manualy other than that
DLittle
09-14-2010, 05:43 PM
The Pot fix just takes place of the TPS you stil need computer input to use that. I want to be able to use o/d with no computer or tps. I read about installing a pressure switch on the transmission but was unclear as to what pressure port to put it in and how to wire it up ?
Onemoparnut
09-14-2010, 06:35 PM
There is an article in the sticky about using govenor pressure that might be your only choice.
http://www.dieseltruckresource.com/d...d.php?t=156988
DLittle
09-14-2010, 09:34 PM
Any other thoughts on this ? I know there's some good tranny guys on here. I think the pressure switch should work . Just didn't know if there way a better way ?
whosdunit
09-14-2010, 09:59 PM
While laying under the" BUS" i looked my trans., & rear end for nos. The rear is a 3.07, the trans(i think) is a 3 speed . I was think'in about a 518 , then some one told me " you'll need a computor" MY thought is now on hold.So i would like to hear about the pressure sw., method also, plus any cutin ,or weldin to be done under rhe trk.
454 no more
09-14-2010, 10:10 PM
Run it to a twelve Volt power source through a toggle switch, you can then run the overdrive manually
whosdunit
09-14-2010, 10:52 PM
hey 454, the o/d ,if it shifts elec., could this be done by wireing it through the tach??
