Auto, hard to pull out of park.
Old 06-11-2008, 12:13 PM
DTR Detective
steelblitzkrieg's Avatar
Seems like it's getting worse or I'm getting weaker? It's intermittent, and sometimes I can't pull it out of park then after 3-4 tries it pulls right out easy as can be?
Old 06-11-2008, 01:49 PM
cincydiesel's Avatar
Could be the censor going to the brake. Can you hear the clicking when you step on the brake.
Old 06-11-2008, 03:06 PM
DTR Detective
Parking brake? Yes. Regular brakes, no.
Old 06-11-2008, 03:07 PM
THEDIESELMAN's Avatar
I have that same problem from time to time haven't tried to figure it out so can't help you.
Old 06-11-2008, 03:23 PM
There is a censor on the regular brake pedal that dissengages the safety switch in the steering colum when depressed. I can hear mine engage when the key is in the start position and I press the brake pedal.
Old 06-11-2008, 03:37 PM
DTR Detective
I'll check it...Is it an actuator where it might be out of alignment or maybe I'm not pushing hard enough on the pedal?
Old 06-11-2008, 03:40 PM
2006Mega's Avatar
mine does it when i am parked on a slight decline which puts more stress on the parking pin/pawl. i should set my parking brake then put in park, hopefully relieving the pressure on the parking pin/pawl.
Old 06-11-2008, 05:07 PM
I dont think it would be something that could fall out of alignment. In regards to pressing the pedal far enough it only takes just a little bit to actuate the censor. The pin/pawl will get stuck once in a while parked on a hill without the parking brake
Old 06-11-2008, 06:14 PM
DTR Detective
Work and home are both slight inclines, I'll try park brake then place in park, but both have been inclines as long as I've owned the truck.
Thanks for the suggestions.
Old 07-10-2008, 04:53 PM
rjjr's Avatar
Dodge has a fix
My 06 got really sticky and I knew there was a problem. Took it in and there was a TSB and they replaced a part inside the transmission. Works perfectly now.
Old 07-10-2008, 07:29 PM
Darryl&Rita's Avatar
# for TSB? Beuller? Beuller?
Old 07-10-2008, 10:00 PM
Seeder's Avatar
I had the same issue with my 06, dealer ended up replacing the complete valve body assm because it had something to do with all being one piece now??? Cannot remember the exact details but it works sweet now.
-Seeder
Old 07-11-2008, 08:58 PM
Still waiting for a TSB #. My '06 has the same issue, but it's new to me(the truck, that is). The dealer service desk looked at me blank-like when I talcked to them.
Old 07-12-2008, 05:15 PM
hardtarget870's Avatar
Same problem
I have noticed the same problem on mine. I have taken it to the dealer they said, "it was fine." But that was a couple of years ago, anyway, what I do to alleviate the problem is to push up and forward when placing the shift lever in park. If I go to shift out and find it stuck, I just press up and fwd (without increasing the pressure on the brake pedal), and the lever is free again. Hope this helps, I definitely want to know that TSB#.
Old 07-12-2008, 09:51 PM
RedRacer44's Avatar
My neighbor who's a dodge cummins tech says that its usually a faulty valve body....well, a part in the valve body. But you have to replace the whole valve body to fix it....he said that only 1 time has it been the sensor for the brake pedal in the several instances he's came across it...
My truck has this random issue as well : ( I get very very very angry when it happens!
Quick Reply: Auto, hard to pull out of park.
