AU Flash
Old 02-14-2009, 05:22 PM
caper11's Avatar
AU Flash
The other day I had the G30 done on my 07 and the dealer said the latest flash was the AU that came up on the Starscan I questioned them on it and they said they just had it downloaded.
What does the au flash do and Is this the latest for the 07? is It a good or bad update?
Old 02-14-2009, 06:11 PM
caper11's Avatar
Ok now I'm a little annoyed I found some old w/o's that on 9-27-07 that i got the AU flash on that day, is that the minimum flash for the g30 and they didn't reflash my ECM with the latest software?
Old 02-14-2009, 09:00 PM
Onelongshot's Avatar
Location: Columbia in the Communist State of Chicago (Illinois)
AZ is the latest for the 2007. see the post for the got ar flash it list all the new updates. The new flash deals with net zero and regenerations at lower speeds.
Old 02-15-2009, 06:11 AM
sabersix's Avatar
As I understand it, the StarScan tool automatically downloads the latest version of the flash over the Internet. It is not possible to flash an earlier version to the truck because the only one available is the newest.
You most likely got the AZ version, but the dumba** dealer doesn't know it.
Old 02-16-2009, 04:10 PM
caper11's Avatar
Ok I got back from the dealer and I was right I had AU and now I have AZ, apparently the g30 calls for only the AU and no higher unless their was a problem. I had 2 stored codes after the G30 and I knew my truck wasn't running right after the recall was completed, hopefully the AZ fixed the problem
Does anyone have a copy of the documentation kit lituature the dealer did not and they never heard of it surprise surprise.
Old 02-16-2009, 09:52 PM
J BODY's Avatar
it doesn't "automatically" down load the latest version. You actually have to manually "search" and it will show if there are updates......dumba**!!
...Also, at times, the scanners have to be updated themselves in order to receive the newer updates.
Old 02-17-2009, 05:08 AM
sabersix's Avatar
Thanks for setting me straight.
Old 02-17-2009, 08:49 AM
XLR8R's Avatar
Hey J BODY what's the easiest way to tell if an ECM was replaced by the dealer?
Old 02-17-2009, 03:22 PM
J BODY's Avatar
Easiest?......I'm thinking pulling the vin up and seeing what repairs were made and where. Any warranty repair will be logged along with an operations code that will tell if the ECM was flashed, or replaced.
Old 02-18-2009, 05:20 PM
dj88382000's Avatar
we do have a new tool that tells us when there is a flash for any module in the truck its called WITECH alot of dealer arent using it yet...i never use the starscan anymore way to slow
cramel
22
10-23-2008 08:06 PM
Flattman
10-16-2007 01:07 PM
CamperAndy
05-18-2007 12:36 AM
8mpg
04-28-2006 10:08 AM
04RAM2500
13
12-17-2004 10:02 PM
Quick Reply: AU Flash
