ATS arc-flow air intake?
Old Aug 26, 2006 | 09:28 PM
smokin'joe's Avatar
Hey fellas,
I'm out here at the diesel truck extravaganza and i seen this ATS arc-flow air intake and i was curious as to weather they would be a good investment or not.
Old Aug 26, 2006 | 09:32 PM
rustyshakelford's Avatar
from what i hear they are great if you looking to add water/meth because they are pre-drilled for that. as far as performance, i think they are on the same level as the banks high ram intake and don't provide alot of performance enhancement qualities. might help the turbo spool up quicker, not real sure though. thats about all i heard. the 300 dollars could be spent on other thing????
Old Aug 26, 2006 | 11:23 PM
dogger's Avatar
ATS ARC Flow
Originally Posted by smokin'joe
Hey fellas,
Got one if you are interested. Changed to a Bank's Technicooler and the inlet is too small on the ARC flow intake. PM me for more information.
L8r,.............dogger
Old Aug 27, 2006 | 04:17 AM
gatf4's Avatar
IMHO , that would be a waste of $300. Turbo diesels are much Different than a gas engine. Under boost, on a stock manifold, I'd bet you'd see no gain in power unless you were at very high H.P. levels over stock. Even then, with the actual intake inlet staying the same size, the actual restriction would be the the intlet itself. I'm talking about the engine side of the High Ram were it bolts to the cylinder head.
RedRacer44
Jan 15, 2007 11:48 AM
Luken
21
Oct 19, 2006 05:42 AM
CTD2001
Feb 3, 2006 09:29 PM
stillsmokin
Jan 22, 2006 11:50 PM
Moose10
Mar 14, 2005 04:34 PM
