View Full Version : ATP Wrap Noise Reduction Anyone?
Jones0027
10-21-2002, 02:35 PM
Hey Guys,<br> Has anyone used the ATP wrap noise reduction kit (found at http://atpwrap.com/dodge_ram.htm)? If so, does it really work? While pulling my camper (and the overdrive off) at 2700 RPMS at 70MPH the noise is deafening. After a few hour it drives me and the family crazy. [eyecrazy]. Help!
Alan_Reagan
10-22-2002, 05:14 AM
I've seen it on one of the Coast Guard boats. I like it but it's pricey.
BigBlackDodge
10-22-2002, 06:24 AM
Mr Jones0027<br><br>Why do you tow in 3rd gear. I've been towing in OD for 284,000 miles. Keep your rpm above 1700-1800 and you'll be just fine. If the trailers pretty heavy- install a Power Edge EZ or a BD Plug in Power and hammer down.
Jones0027
10-22-2002, 07:39 AM
<br>Mr Jones0027<br><br>Why do you tow in 3rd gear. I've been towing in OD for 284,000 miles. Keep your rpm above 1700-1800 and you'll be just fine. If the trailers pretty heavy- install a Power Edge EZ or a BD Plug in Power and hammer down.<br><br><br>BigBlackDodge,<br> I have an automatic tranny. Whenever I leave the overdrive on (in semi flat country in Southern Illinois with the cruise set at 70mph at 1900rpms) the tranny hunts for gears when going up a hill. :'( When I take the overdrive off, the noise kills us for long trips. [eyecrazy] The trailer is about 6250lbs dry weight, loaded over 7500lbs. I don't mind the shifting, as long as it doesn't blow my tranny out (which as we know are prone to go out). Which is why I was thinking about the ATP wrap. If it muffled the noise enough with the overdrive off I'd spring for the $700. If the ATP wrap doesn't work well enough, then why spend the money. ::) Anyway, thanks for the input. I appreciate it. Adios.
vBulletin® v3.6.7, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
