PDA
View Full Version : ATF Fluid
Jbolt001
11-15-2002, 01:07 PM
I feel rather silly asking this but I have never changed the tranny fluid myself and I can't find my owners manual.<br><br>What type of ATF fluid is recommended for my truck.<br><br>I'm going to do my tranny temp gauge this weekend.<br><br>thanks
dalton4
11-15-2002, 02:46 PM
Check your tranny dip stick. Required fluid type is usually stamped into the stick. My 96 calls for ATF+3 fluid.<br><br>Jerry
RCW
11-15-2002, 07:09 PM
When you change your filter, do not get any dirt in the system and whatever you do, do not blow any air back in any of the passages. Just drain the fluid, change the filter, put on a new gasket, and put it back together after you clean the pan with brake cleaner and let it dry. Do not use brake cleaner on the valve body or any of the transmission internals.<br><br>You will find crunchies from ground metal and friction material in the pan, do not panic, that is normal (unless you have converted to hydraulic oil or Amsoil ATF at some time in the past).
Jbolt001
11-15-2002, 08:34 PM
<br>Check your tranny dip stick. Required fluid type is usually stamped into the stick. My 96 calls for ATF+3 fluid.<br><br>Jerry <br><br><br>Thanks Jerry. Boy do I feel stupid. I don't know how many times I've looked at the dipstick and never paid any attention to what was on it above the fluid level marks.<br><br>RCW- thanks for the heads up on the fluid change. I'm sure I would have been back here asking what was wrong.
nascar mark
11-15-2002, 08:35 PM
93 or older use dex+2 as we don't have lock up tc.<br><br>mark<br>PDR - Black Sheep Racing
