arrow draft wheel spacer ?'s
Old 05-03-2007, 12:24 PM
danimal 95's Avatar
ok so i put my 1.5" wheel spacers from arrow craft on with my new tires,305-70-17 maxxis bighorns.i had to open the holes in the outer 2 rear wheels up with the reamer that they supplied,my question is now that the 2 wheels have a larger hole than the rest can i use the reamer to open up the other wheels so i can still rotate the tires around???are they hub-centric in which case the larger lug holes shouldnt matter correct??
Old 05-03-2007, 05:40 PM
wap
wap's Avatar
It should work in theory but I do not recomend it, it just doesnt seem like a good idea to me.
I might run a reamed wheel on the factory lugs in a pinch but I dont know if would be a good thing to do daily.
Maybe someone that KNOWS can chime in.
Old 05-03-2007, 05:45 PM
CrazyCooter's Avatar
If you run hubcentric wheels, reaming the bore hole will cause a balance issues and possibly make you lugs come loose over time.
I would have the spacers machined to accept the stock bore diameter.
Old 05-04-2007, 06:33 AM
wap
wap's Avatar
You ream the lug holes, not the center bore.
You are refering to the center bore in your statement right?
Old 05-04-2007, 08:38 AM
danimal 95's Avatar
yes the center bore,in theory the wheels being hub-centric which they are, and the lugs are not and acorn style so they dont center the rim on the hub it should be ok to ream the rest and not worry aboiut it.i just wanted to see if anyonew was doing this successfully
Old 05-04-2007, 10:19 AM
So....if you ream out the center hole and you lugs are not acorn style......what will center the wheel when you rotate it to the front?
Right now the ceter hole carries the load, the flat lugs just hold the wheel to the hub.
If the center bore is not there tight enough to center the wheel, under heavy loads the wheel could move on the hub loosening the lugnuts.
Old 05-04-2007, 03:25 PM
danimal 95's Avatar
So....if you ream out the center hole and you lugs are not acorn style......what will center the wheel when you rotate it to the front? the factory wheels are hub-centric which means the wheel is centered by the hub not the lugs
im not asking about reaming the center holes im asking about reaming the lug holes,i realize that if i ream the centers nothing will center the wheel
Old 05-04-2007, 04:24 PM
Gotcha! My bad.
Not harm done then. Ream away!
Old 05-07-2007, 11:41 AM
danimal 95's Avatar
still no one has awnsered the ? if it would be ok or not
vepchl
08-03-2012 04:58 PM
biglou
07-07-2010 08:30 AM
smokinram99
06-21-2009 08:14 AM
biglar
04-04-2008 02:45 PM
Quick Reply: arrow draft wheel spacer ?'s
