APPS signal questions for high idle.
Ok so I want an electronic high idle control to my truck and have come to the conclusion I am going to have to make one. So does anyone know how the APPS works and the type of signal it sends to the ECM?
Location: In Oroville, Ca., same house for past 46 yrs!
put a meter on them and check which has the output from 0 to +5vdc. then check the other wire... it may have the opposite +5vdc to 0 as it's taken from idle to full throttle. It might be that one is simply a seperate isolated ground wire.
wWhat were you planning? Using a solenoid to hold open the APPS cam?
Like the olde style carbs that had a fast idle solenoid that held the throttle open a tiny bit.
I suspect you are trying to use someething like a toggle switch with a load resistor inline to hold a specific voltage vale that corresponds to a certain idle rpm. Or use a variable potentiometer like a volume control and input a variable signal to the ecm to make it think you're holding your foot on the pedle just slightly. Huh?
while you ponder and answer this post, I will look over the schematics for that area and l;et you know what i find out for my truck.
pg 887 of manual schematic
ok, here's a page from the manual with the connections. It looks like the terminal shown on the far right is the idle circuit. Good luck.
jmccart
06-12-2007 02:12 PM
