APPS sensor
Old 05-23-2006, 09:33 PM
WalkerMike98's Avatar
APPS sensor
Where is the best place to get one. I am having dead pedal syndrome and figured I would start with this if it is not to expensive. I have read it could also be a dying VP, but no codes or engine light.
Old 05-23-2006, 10:37 PM
crobtex's Avatar
The VP44 will not always set a code. Try the APPS_RESET first to see if that might fix the problem. New ones are about $350 new from Cummins, but some on here have bought them off of Ebay for about $100.
Old 05-23-2006, 11:08 PM
piperca's Avatar
How did you check the codes? Make sure you check thoroughly, with a scanner, before you do anything else! When my APPS went it was just a stutter in the throttle. When my VP went it was dead pedal.
Old 05-24-2006, 08:44 AM
Clunk's Avatar
Thumbs up
My pedal will go dead during a hard left turn and return after a few seconds.
No codes on the odometer.
I can also push the clutch in and let the motor rev up then dump the clutch or hit a pot hole to get it back again so I'm going to check the wiring and connectors before I get too excited.
Old 05-24-2006, 09:01 AM
bamadzl's Avatar
I'm supposed to get one from Cummins today for $287 plus tax.
The Dodge dealership lists the part for $455, but surprisingly the guy I talked to said he would sell it to me at wholesale for $350. Definately call around to get the best price.
The parts guy at Cummins first told me that I would have to buy from Dodge. I called him back and gave him the part # below for my truck and then suddenly he could get it. I believe the part numbers are as follows, but have cummins verify that the application is correct.
3970084 for Auto. Trans
3970085 for Manual
Brad
Old 05-24-2006, 10:32 PM
THank you guys.
supr
18
05-21-2007 09:29 AM
jd4030
01-05-2006 01:09 PM
calls
38
06-06-2005 06:08 PM
CTD2001
05-24-2005 06:29 PM
tishmael
08-31-2003 11:49 PM
Quick Reply: APPS sensor
