APPS Issue?
Old 09-05-2011, 07:42 PM
GreatTruck2001's Avatar
APPS Issue?
I have read many APPS posts, but my issue doesn't seem to match any of the posts I've found. After I mash the pedal to accelerate hard it gets very soft and hyper-sensitive. Also, the trans shifts differently, holding lower gears longer and down-shifting earlier. When I shut the truck down, the problem disappears and the pedal pressure & trans return to normal. Issue occurs either with Quad XZT+ on power setting or fuel economy setting.
Any thoughts?
Old 09-16-2011, 09:22 AM
gsbrockman's Avatar
Have you attempted the APPS reset procedure by chance???
Old 09-19-2011, 07:34 PM
Yes, reset several times. Just replaced the APPS unit and issue persists. Thinking it make be a problem with the TV cable.
Old 09-20-2011, 01:07 PM
OK - really easy solution!! The TV cable was hanging up due to corrosion! Lubed it up and problem is gone!! Forgot my motto: KISS (Keep It Simple Stupid)
gwbrehm
12-23-2009 08:36 PM
OCMerrill
11-18-2009 09:40 AM
StevenAg03
15
12-08-2008 07:06 AM
megamac
07-15-2007 02:19 AM
Quick Reply: APPS Issue?
