APPS experiences
APPS experiences
Would some of you guys mind commenting about the results upon doing the APPS:
https://www.dieseltruckresource.com/...p;onlynewfaq=1
Things got better for you or didn't change anything at all or things got worse ?
Re:APPS experiences
I did it, and it seemed to be more responsive. I think it makes the biggest difference if you do it after different driving conditions. For example- If always city driving, do it before you go on an extended hwy trip and vice versa.
Mike
Mike
Re:APPS experiences
On mine it did improve shift points and therefore acceleration. Since I had some noise on the APPS signal to the PCM I installed a noise filter and had to recalibrate again.
AlpineRAM
AlpineRAM
Re:APPS experiences
After reading this thread, I went back and read the procedure again. It seems I left out a step. I didn't set the parking brake as prescribed. Will that make a difference?
Re:APPS experiences
[quote author=rattle_rattle link=board=4;threadid=21239;start=0#msg199596 date=1066815074]
[/quote]
As far as I know, it won't make any difference if you don't set the parking brake. I didn't set the PB when I performed this on my truck, however it still cured my tranny from occasionally dropping out of lock-up in overdrive at 65 mph. ;D The truck has not done it again since I did the reset.
[/quote]
Re:APPS experiences
OK...I did the reset last night and WOW...shifting and over all acceleration improved dramatically...Smooth...Smooth...Smooth
:P
:P
PanteraGSTK
12-06-2005 05:24 AM
2500CTD
09-02-2005 11:06 AM
CrashCade
07-06-2005 04:27 PM
dgm
04-18-2005 09:37 AM
