APPS Code and ole 1693
Old 09-10-2005, 08:12 AM
k9judge188's Avatar
I threw an APPS low voltage code and cleared it by doing the reset. Now I still have the 1693 code. Does the APPS code automatically throw the 1693 code or do I have other problems? Will disconnecting the batteries clear the 1693 code? Truck is running fine now after the reset.
Old 09-10-2005, 09:18 AM
Big Deezul's Avatar
you should be able to clear the 1693 with a snap-on scanner.
did you adjust your apps? It needs to read at leat .49 volts or it will just throw that code again and make your truck run badly
Old 09-10-2005, 09:29 AM
k9judge188's Avatar
I haven't checked the voltage. I guess if it comes back I will probably have to replace it. Will a new one solve this problem or is there another problem that is causing the low voltage?
Old 09-10-2005, 12:49 PM
Big Deezul's Avatar
you can just adjust it if the problem is a low reading
darrenG
07-10-2006 04:59 PM
jt_gladstone
08-09-2005 11:24 AM
Gene007
05-16-2004 05:55 PM
j
03-09-2004 11:45 AM
roadrat
01-18-2004 03:07 PM
Quick Reply: APPS Code and ole 1693
