Anyone running a dual pod steering column mount???
Old 01-05-2007, 10:21 AM
53 willys's Avatar
I have been debating on moving my gauges from the over windshield 3 pod to the dual steering column mount and the SRT-10 a-piller mount.
I have a few questions...
1.does anybody make one that matches the 06 column color??(i don't want to paint it)
2.does the dual mount block your oem gauge view??
3. do Optix gauges fit?? I read in one post that a guy was having fitment issues with the optix gauges??
I searched the forum and found some stuff but it was mostly older trucks 04's and they already have a black column and mine is grey
threads I found searching...https://www.dieseltruckresource.com/...G+COLUMN+MOUNT
thanks for your help
53
Mark
Old 01-05-2007, 10:26 AM
morkable's Avatar
I had the steering column, but got rid of it and put in the overhead counsel. I had to paint mine. I also have the srt10 guage pod, I really like it, but I could only get 1 guage with the attitude holder, so I put my boost there, I run the attitude for egt and engine temp. and I have tranny temp, fuel pressure, and rail pressure in the overhead
Kevin
Old 01-05-2007, 10:42 AM
RamWheelsBy4's Avatar
I have a dual steering column mount. I am happy with it. It does block trans select display, but thats about it. I have the Optix Rail Pressure guage and Autometer Fuel Pressure gauge mounted in mine.
Old 01-05-2007, 10:44 AM
driverno8's Avatar
Blocks a bit, but you get use to it.
http://dodgetruckworld.tenmagazines....no8/269679.jpg
Old 01-05-2007, 11:05 AM
morkable's Avatar
The reason I changed mine, is that it was causing pressure on the column and was making my multifunction lever (read signal light switch) to sometimes not work, it would actually signal left when i wanted to go right,, stuff like that
Kevin
Old 01-05-2007, 11:16 AM
53 willys's Avatar
Kevin
That's weird!! I would not think the little extra weight on the column would cause all that???
if you had not had problems with the turn signal's would you have kept your column mount?? is it easier to see then the overhead mount??
Old 01-05-2007, 11:22 AM
53 willys's Avatar
I wish they would have rolled the gauges off to the sides a little more
I have a standard trans so that should not be an issue.
does the optix rail gauge fit OK in that pod?? I read while searching that the optix boost,fuel pressure did not fit very will?? he said it did not push in the pod all the way because the boost and fuel line was to ridged???
Old 01-05-2007, 11:28 AM
I suppose there could be some issue with boost and fuel lines fitting ok, but both of my gauges are electric and only wiring to deal with. The Optix and Autometer fit the same in mine.
Old 01-05-2007, 11:36 AM
53 willys's Avatar
ooh, I never knew the rail gauge was electric..
anybody else?????
any 06 owners have one yet??????
Old 01-05-2007, 11:48 AM
morkable's Avatar
I think that the pressure was caused by feeding the wires through, and not enough relief from the manufacturer. As for whats better, I think that would depend on how tall you are. I am 6 2, and have a long body, so I sit rather high, and I found that the steering wheel tended to block the guages somewhat. I like the overhead, except for the last guage, it gets blocked at the top of it, but all I did to remedy that is turn the guage so that the part that I need to see is in easy sight. Another reason I like it overhead is that I dont have to take my eyes off the road to see it.
Kevin
Old 01-05-2007, 01:14 PM
Gary C's Avatar
It didnt take long to decide to put my guages elsewhere...
Old 01-05-2007, 06:44 PM
53 willys's Avatar
where did you move them to....
Old 01-05-2007, 07:05 PM
djbikeman's Avatar
I have one and removed it when I installed the Attitude monitor. It does block the lower inside corners of the speedometer and tachometer. It also blocks most of the warning lights. I would have to look over the guage pod to see my WTS light.
As far as I know, they only come in black.
Old 01-05-2007, 07:20 PM
boostjunkie1's Avatar
A-Pillar is the way to Go---along with the Dash Mounted Gauge Pod-----that is probably what I'm going to do with mine.....Was looking at the Commander But I think that I will stick with the analog gauges for now. I trust them a little more!
Old 01-05-2007, 07:23 PM
morkable's Avatar
Is anyone using that dash mount?? I was looking at it, but was worried about running wires etc
Kevin
Quick Reply: Anyone running a dual pod steering column mount???
