Anyone running 90hp Nozzles with stock CP3?
Old 09-09-2009, 03:32 PM
BigBully's Avatar
On an 04? If so how does it do?
Old 09-09-2009, 03:44 PM
BIGDAN65's Avatar
i am running 80's on stock cp3, with AD 150, it has plenty of fuel for my turbo
Old 09-09-2009, 03:57 PM
69nova's Avatar
My brother is running them in his 05. The stock cp3 was ok. Now he has twins on his truck and he needs a modified cp3 to take advantage of the 90hp tips and twins
Old 09-09-2009, 04:11 PM
UnrulyNFS's Avatar
I ran 100hp injectors on the stock CP3, but ran out of air and rail pressure. Lots of smoke when the rail pressure was low too. I took them back out until I get around to putting my second CP3 on there. My last dyno, pressure was never over 15K on each run with the MP8 maxed. No popping, but still not enough to feed the bigger tips properly. 15 more hp over the stock tips however.
Old 09-09-2009, 06:10 PM
JL4822's Avatar
I have been thinking about doing that, smae thing, just not sure, on were to get the CP3 stack, kit, and what kind of injectors to also get, I know the truck will handle it, but got some issues.. anyone got any sugestions, as to which kit to get, and which injectors as well.. tks.
Old 09-09-2009, 06:50 PM
BigBully's Avatar
What altitudes are you guys at, I am at 8700 feet and worried about Rattle, I do have Compound turbos and the truck runs great on 50hp nozzles but i want just a tad more. Do you think I will be ok or do i need the Modded CP3?
Old 09-09-2009, 09:18 PM
bob4x4's Avatar
It all depends on how much electronics you run on top of the injectors..
Old 09-09-2009, 09:34 PM
BigBully's Avatar
Just running a Smarty
Old 09-09-2009, 11:13 PM
JL4822's Avatar
I am running a smarty, stacked with a MP8, and the Air Dog II 165gph, and a different turbo, right now it dyno at 562hp, and 1034 ftlbs, im looking to get into the 600 to 650 hp range, and get maybee in too the 1200 ftlbs range. But soo far this is a hell of a lot better, than my old banks 6 gun system, also the smarty is too cool my EGT has droped 100 degrees or more, on a hard pull. and I hve yet to get the B&D single B special on, had some issue with the dam mount.
Old 09-10-2009, 10:49 AM
BigBully's Avatar
What about running the Fass through the stock filter? I am at 15psi and it does drop a little bit when I hammer down.
Mike Holmen
10-01-2011 08:49 AM
SlowSixSpeed
11-22-2007 04:15 PM
frostytj
04-20-2007 11:32 AM
ramtd02
04-19-2007 06:16 PM
PourinDiesel
04-02-2006 09:38 PM
Quick Reply: Anyone running 90hp Nozzles with stock CP3?
