Anyone Make Shocks For A 2WD With A Two Inch Lift?
Old 08-13-2007, 03:58 AM
EverydayDiesel's Avatar
I have a leveling kit (2" lift) and I need to replace my shocks.
I am having trouble finding shocks made for stock + 2"
Old 08-13-2007, 07:27 AM
signature600's Avatar
I have Skyjacker Hydro 7000's on my 95 dually with a 2" lift...I don't have the numbers anymore, but any skyjacker dealer should be able to help you...or you could call Skyjacker direct!
Chris
Old 08-14-2007, 10:40 PM
I called blisten and they claim they dont have a +2 for a 2WD???
Old 08-15-2007, 08:02 AM
Did you call Skyjacker??
Chris
Old 08-15-2007, 11:46 AM
Muted User
LOGAN's Avatar
call ProComp, give them your measurement eylet to eyelet as the truck sets normally and they will probably have a set for you.
Old 08-18-2007, 08:22 PM
Chris
I called them and they only have them for 4wd.
Does anyone know what the difference in shocks between a 2wd and a 4wd? Its just a shock right?
Old 08-19-2007, 12:37 PM
R.T.D.H.S.P.'s Avatar
ProComp definitely does...I have them. Bilstein should have them as well though.
Old 08-19-2007, 01:03 PM
Well, whoever you talked to doesn't want to help very much...I have a set of them
A Shock is a shock...to a point. I don't remember if a 2wd and 4wd will interchange or not!
Chris
Old 08-19-2007, 05:20 PM
Chris
Can you Please find me a part number? I cant find them anywhere and I would like to run blilsteins.
Old 08-20-2007, 04:22 PM
bump...id really like to know what series you went with and a model number if you have one!
Old 08-20-2007, 05:11 PM
I've looked, and I can't find the part numbers Skyjacker gave me! I've had them about 3 years...so the shocks are so rusty you can't read them either!
Chris
Old 08-21-2007, 06:07 PM
Thanks for looking! I appreciate it.
Ill give them a call and see if I can get a hold of someone else.
Old 08-21-2007, 06:49 PM
Are you calling Billstein, or Skyjacker??
Chris
Old 08-21-2007, 06:51 PM
Ive called both but Im going to give skyjacker another call.
How does skyjacker compare to bilstein?
Old 08-22-2007, 01:04 AM
zfort001's Avatar
Well since yo are having trouble finding shocks for a 2wd 2" over stock try to locate a set of shock extensions. They are extensions that bolt to the top of the shock and gice you about 2 more inches of shock length. They may help your situation and keep the shock in the stock operating range. I used them on my Toyota rat rig in the early 90's after i installed a double shock kit and was waiting for my new shocks to be dilevered.
Quick Reply: Anyone Make Shocks For A 2WD With A Two Inch Lift?
