PDA
View Full Version : Anyone to install pyro gauge?
WhozNxtLS1
05-10-2008, 11:36 AM
Pm me with a price. Located in South Jersey Moorestown area
WhozNxtLS1
12-21-2008, 06:37 PM
ttt.....looking to do this soon
Juniorphil
12-21-2008, 07:27 PM
You are away from us up here in northern nj. i have been down that area for work a good 2.5 hours away. don't know anyone down that area i know there are other members down in your area
Green04HO
12-21-2008, 09:03 PM
It's very easy to do. Get yourself a small telescoping magnet that fits in the hole and pull the shavings out of the manifold. I've done three of them this way and it works well.
If I was closer I would throw it in for you, but I'm up in Vernon. Any questions just ask.
WhozNxtLS1
01-01-2009, 07:55 PM
It just scares me to think of the damage that I could do if I do it wrong, I've even thought of taking the manifold off to do it lol
98whitelightnin
01-01-2009, 08:22 PM
Just drill steady and straight. Keep grease on your bit and dont run your tap all the waydown or your hole will be to big. Like Green said get a magnet and get as much out as you can, I have done several this way also.
Green04HO
01-01-2009, 09:12 PM
You will get 99% if not all the chips out with the magnet. After install is complete start the truck up and let it idle for a couple of minutes and with no real exhaust energy to spin the turbo up anything left will blow right through with no damage to the turbo.
Green04HO
01-01-2009, 09:17 PM
dont run your tap all the way down or your hole will be to big..
Yes this is a very good point. Your thread is a tapered pipe thread. I used some high temp anti-seize on the ones I did also. You want your probe to sit in the center of the manifold tube.
