anyone ever had VP-44 timing error???
Old 05-27-2006, 07:04 AM
pbolte61's Avatar
Anyone ever had an Injector Pump Timing error, just replaced the lift pump, reset the codes, and since the supply pressure to the injector pump is now good, the truck recovers fine?
Thanks,
Paul Bolte
98.5 24V White 3500 2wd dully named Casper.
Old 05-27-2006, 07:33 AM
P.J
P.J's Avatar
Probably not going to last. If so, you are one of the luckiest men I know.
Old 05-27-2006, 07:45 AM
pbolte61's Avatar
didn't do it, just curious
No, I didn't try that option. My wife and I left on vacation to Canada, we got 200 miles from home and pulling a mountain pass, started loosing power. Got to the next town, pulled into a Dodge dealer, diagnosed the VP-44 timing error, pulled the trailer to a campground a mile away and spent two days there while they replaced the injector pump and lift pump. I did get an upgrade option to the lift pump. The new pump is now in the tank and the dealer says, I should have no more lift pump problems, which should save the injector pump from now on. I hope so, I've got 157K miles on the truck and this was the second injector pump. First one failed at 114K.
Paul
Old 05-27-2006, 08:04 AM
P.J
P.J's Avatar
I think you did the wise thing by having it replaced. You should get a fuel pressure gauge installed in the cab so you can monitor the pressure coming from the lift pump (lack thereof more than likely your cause for failure).
The intank lift pump is the only one that Dealers will install now, it runs at a bit lower pressure than the original firewall located pump, but is suppposed to be a superior desing (and location).
Good Luck buddy, happy camping.
Old 05-27-2006, 11:44 AM
J BODY's Avatar
I've had an injection pump timing error........and installed an injection pump.
Old 05-27-2006, 01:55 PM
P.J
P.J's Avatar
One or Two, right?
Old 05-27-2006, 03:17 PM
graphitecumnz's Avatar
I had a P0216 when I installed my FASS and the truck ran strong for 13 months and then died...
Old 05-27-2006, 04:22 PM
J BODY's Avatar
Originally Posted by P.J
One or Two, right?
...only refering to my truck. I've kind of lost count on how many I've done in the last three weeks .
t-15 firefighter
02-09-2008 11:48 AM
Spooler
11-01-2007 09:20 PM
043500QC
08-28-2007 03:12 PM
t-15 firefighter
09-17-2005 01:08 PM
Quick Reply: anyone ever had VP-44 timing error???
