anyone with dual pumps using a MP-8 ???
if so, and if you're is anything like my PPE duals, it has the electronic control box that wires into the OEM connections.. ( MAP/ FPS ). Well so does the MP-8. So now, on top of the OEM connector I have the control and the MP-8 connected.
Well, that didn't seem to work too well because my truck wouldn't start and it threw about 5 different codes. I removed the MP-8, cleared the codes and all is good now.
I may just have to call TS Monday but, does anyone know if it's a problem stacking the connectors like that ? I know I had them connected in the correct locations.
I use the Ramifier which is the MP8 before it was the MP8.
Mine seems to work with my PPE duals however when turned up all the way its just too much pressure/aggression.....of course it did this even back when I had a stock pump.
GotStacks
05-23-2009 12:08 PM
JJK98CTD
03-29-2009 10:45 AM
VaultRam
40
04-10-2008 09:45 PM
