any one good with ac systems...
Old 07-28-2006, 09:53 AM
Ramdriver15's Avatar
i evacuated, vacummed for 15 minutes, and recharged my system to specs and it work nicely for about a month. Well i dye tested it and no leaks found... compressor kicks on and off normally... what to do... any ideas
thanks
john
Old 07-28-2006, 11:20 AM
pooperscooper's Avatar
do you have a set of gauges to check the pressures? normally when an ac system goes to crap it is because it has a leak or has air in it. did you check the evaportor connection under the dash for leaks. they are known for leaking. is it just not cold now or as cold as it was before?
Old 07-28-2006, 11:53 AM
kawi600's Avatar
Im replacing my evap and liquid line soon.. how would you make sure that connection doesnt leak once installed?
Old 07-28-2006, 01:11 PM
redramnc's Avatar
Collapsed hose, deteriorated filter/dryer, orifice clogged - all culprits. You need gauges to see if you are pulling vacuum on the suction line (lo side) or overpressuring the high side. Feel for a colder-than-normal component - that is usually a sign of a blockage at that point. Pump could be wore out but that will show in the pressure readings.
Not an expert but I have seen alot of crazy stuff over the years.
Old 07-30-2006, 09:03 AM
the air when i first fixeed it was feezing and i had to shut it off!!! now its just cool, not cold and doesnt do as good a joba s having the windows open..... also my dads 99 gasser did the exact same thing....
thanks
Old 07-30-2006, 09:07 AM
i have an a/c machine at work that i can use and it has gauges, also i can put more die through it. The one thing i dont understand though is all the components outside the truck are ice cold and condensation forms imediately, and it does have pressure in it still. How would i go about checking the orafice tubes and or evaporator dryer... im not an expert on these things yet but i have the general concept... We get the full lesson this year at school so if i dont get it now over the summer there is our project for the schopol year.
RobV2500
15
06-01-2008 08:16 PM
JIT
01-15-2007 11:43 AM
WL.
04-17-2006 04:43 PM
possum
08-23-2005 11:29 AM
Mopar_Mudder
11-01-2002 07:42 AM
Quick Reply: any one good with ac systems...
