Any good B100 Low Temp Anti-Gel Tricks???
Just found a steady source of B100 and looking for some real world advice
regarding an "effective" Low Temp Anti-Gel additive/product.
To be more precise (though my heated WVO bed tank runs wvo like a champ year round) I want to run B100 in my trucks 35gal (unheated) stock tank this Winter. However, as with most B100 "gelling" becomes a major issue when temps fall below 40deg (F). Unfortunately, there are all kinds of B100 low temp anti-gelling products on the market claiming their product is best and the more I research B100 anti-gel products, the more difficult it is to separate facts from the hype (without testing 'em all and breaking the bank in the process). Seems Mixing B100 with straight Diesel @ $3.99ish/gal is a no brainer but if there are any other tricks or something less expensive/more effective ... I'm all ears!
(Recent reply I recieved from a major BioDiesel Supply House...)
Most of the products out there really don't work that well (the chemistry behind it is really difficult).
The two I've heard that actually are worth a darn are:
1) Amsoil Cold Flow Improver (we tested it, it worked marginally well)
2) Technol B100 Biodiesel Cold Flow Improver (I've had customers report that it does a fairly decent job as well).
Outside of those two, I have no other experience except to say that diesel fuel is still an awesome anti-gel additive and still the cheapest way to keep B100 from gelling.
Biodiesel Magazine recently did an article on anti-gel additives...
Short version: They all suck & should all be tested
Long version:
http://biodieselmagazine.com/article...lowing-growing
I would say a lot of it depends on your feedstock though. I just did an article on this very topic that may be of some benefit. Here's the link:
http://www.utahbiodieselsupply.com/blog/archives/1587
Long version:
I run SVO in my stock tank, but I cheat and preheat with my Webasto engineheater feeded from a jerrycan in the bed.
When temps get near 50 or so (F) it gets 15 mins. And it starts right up, Wien temps get to 30ish I increase that time to 20mins. And when it gets to around 15 I start to feel loss of power and dump in 5gallons of diesel, then fill up with SVO and everything is good.
I understand your thoughts on the diesel/antigel, been there myself, but after hearing about numerous fantastic products with little to no explanation, and at least twice as many "bright" ideas, I figured I'd rather play it safe.
Slev
Slev
What I've read...If the bio is not cleaned right...The jell temp goes up...I don't know how true this is...I have done stupid things like running 50/50 at -20...Just by luck,I haven't jelled up......yet..But I do care power service 911,just in case...
BA05'CTD
16
10-27-2005 02:58 PM
