Anti-slip addative or No anti-slip addative?
Old 08-23-2003, 05:25 PM
BADodge2003's Avatar
Does anyone have a definite answer as to wether or not I need to add anti-slip addative for the American axles. The owners manual says no, the dealer says yes. Who is right? :-
Old 08-23-2003, 06:03 PM
Matt400's Avatar
Re:Anti-slip addative or No anti-slip addative?
[quote author=BADodge2003 link=board=20;threadid=18767;start=0#msg176035 date=1061677509]
[/quote]The factory shop manual says yes for the 1500's limited slip but no for the 2500 & 3500's limited slip units because those differ in design and do not require it.
Old 08-23-2003, 10:38 PM
Casey Balvert's Avatar
Your 2500 truck does NOT need this additive.
Casey
Old 08-24-2003, 02:17 AM
SuperGewl's Avatar
[/quote]
As stated, NO do NOT add any type of limited slip tourque additive, it will void the warranty. also make sure you check the level of fluid in the rear-end. On the earlier models they were all shipped at least 1 qt low. The gear lube weight (I believe) is 75w 90.
Just my .01 worth.
Old 08-24-2003, 07:22 PM
NC_Mog's Avatar
Re:Anti-slip additive or No anti-slip additive?
I don't think it would void the warranty, but no you don't need it. No clutch packs or cones or any other friction devices in it. Its an all gear LS.
Rammandan
11-02-2006 03:26 PM
ppsi
05-31-2004 12:50 PM
dodgedude361
01-31-2004 02:56 PM
Trusty Steed
01-28-2004 07:33 PM
coobie
12-31-2003 11:52 AM
Quick Reply: Anti-slip addative or No anti-slip addative?
