Anti Lock brake light
Old 11-25-2009, 08:30 AM
tcozad's Avatar
The ANTILOCK BRAKE and BRAKE warning light is coming on. This is now the third time this has occured. It usually happens after about 4 hours of continuous driving. Everything else is fine and the truck drives great. 2006 4x4 3500 Dually. Any suggestions. Thanks, Tim
Old 11-25-2009, 05:53 PM
Roadmedic's Avatar
You will probably have to replace the VSS on top of the rear axle.
VSS is the speed sensor. Mine went out back around 50,000 miles.
Old 11-26-2009, 11:07 AM
tcozad's Avatar
Thanks, I will check it out.
Old 12-05-2010, 05:10 PM
tcozad's Avatar
Replacing the VSS corrected the problem. About $15.00 and 10 min was all it took. Thanks Roadmedic.
Old 12-05-2010, 07:41 PM
Roadmedic's Avatar
I found the answer here back when I needed. Glad to pass it on to another.
Old 12-06-2010, 12:24 PM
ssandlin's Avatar
OK, educate me please. What does VSS stand for and how is it used?
Thanks,
Old 12-06-2010, 12:28 PM
Chris Taylor's Avatar
Vehicle Speed Sensor
The Anti-Lock Brake System (ABS) uses VSS information to determine when a wheel is locked up and releases pressure to that wheel to maintain directional stability. Some vehicles use seperate sensors for the ABS, but it is common that the computer uses the information from the wheel sensors to act as a VSS.
Old 12-06-2010, 03:03 PM
railroaderone's Avatar
hate to derail this thread my 07 2500 turns on the brake light on the dash at 1700 rpm under a hard pull any ideas . Thanks in advance
Old 12-06-2010, 03:16 PM
ssandlin's Avatar
Thanks ChrisTaylor. Is there just one sensor that collects information from each wheel or multiple sensors e.g. one for each wheel?
Old 12-06-2010, 04:06 PM
Sensors on each wheel
Bruce M
01-06-2011 10:14 PM
NO_SPRK
01-26-2009 10:55 AM
ro9beam2002
03-15-2008 09:54 PM
russ300h
12-10-2007 05:06 AM
DODGEZILLAW350
05-20-2007 06:00 PM
Quick Reply: Anti Lock brake light
