Another TST with codes, please help
Old Nov 11, 2004 | 02:36 PM
fordper4mance's Avatar
I installed my PMCR and all went well until i was done. I fired up the truck and it ran fine and seemed to perform as expected. I then noticed my check engine light was on. The key trick revealed these codes: P0107- manifold absolute pressure too low, P0073-Ambient temp. sensor high, P0633-SKIM key not programmed in PCM. I drove the truck and all is functioning well other then the engine light on. Can anyone tell me what could have caused these and how i might go about checking something or fixing them. Thanks Andy
Old Nov 11, 2004 | 03:37 PM
WhiteSport600's Avatar
Sounds like maybe you had a loose connection. Double check them and if all is well, drive it for a while. The light should go out within 10 starts and some normal driving. If you have no other problems, don't worry about it. If the light stays on, call TST and talk to Greg... or just go ahead and call him anyway, but he'll tell you the same thing... Good luck and enjoy your newfound power
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
SuperiorRam
Mar 15, 2007 03:10 AM
MoparRiggan
Jan 17, 2006 12:43 PM
