Another "Will they fit?" thread
Old Mar 26, 2008 | 11:14 AM
Hot Rod 4's Avatar
I found a set of rims I am looking at buy but I wanted to check to see if you guys think they will fit.
Rims
18x10 Helo
5.89 BS offset unknown
Tires
305/65's or 325/60's
I want these to be tucked under the fenders as much as possible. If they stick out more than 1.5in. its to much. The tires I have yet to decide on but I want 33's and close to 12.5. I was thinking something like Mickey Thompson atz's.
So will it work
Old Mar 26, 2008 | 09:20 PM
dslpwr81's Avatar
They will stick out of your fender by about 3 inches. They are very few options for us Dodge owners. I have only found about 15 sets that fit, which sounds like a lot, but not when there are 500 differents ones out there.
Old Mar 26, 2008 | 11:33 PM
Lsufan78's Avatar
i don't think it'll be 3 inches....my 17x10's with 4.25" backspacing don't even stick out that much.
those wheels will be ok, but they will stick out a little being that they're 10"s wide...you'd be better off finding a 9" wheel if you want it closer to being under the fenders.
Old Mar 27, 2008 | 06:23 AM
Hot Rod 4's Avatar
Thanks for the replies. Does anyone have pics of a similar setup? It does not have to be 18's just something with 10in. wide wheels and close to similar backspacing
Old Mar 27, 2008 | 09:50 AM
cquestad's Avatar
Stock Rim is 8" wide with 6.5" of BS.....so they stick past the hub face 1.5".
Compare a 10 wheel with 5.89" BS...they stick past the hub face 4.11"...
So...4.11-1.5 = 2.61" over the stock geometry...
Simple math...and that is just the wheel. IF you used the 325's...they are 13-13.5 " wide at the widest verse a ~10" wide OEM tire. So you have another 1.5 to 1.75" is tire width additional on the outside (and inside).
So...it is more like 2.61" + 1.5" = 4.11".
THEY STICK OUT!
PEAKSTRYDE
Oct 11, 2007 04:20 PM
schv
May 2, 2007 09:55 PM
AlpineRAM
Jun 23, 2004 06:33 PM
