Another P-pump conversion question
Old Dec 11, 2010 | 03:51 PM
The_Head's Avatar
IF you install a P-pump engine in a first gen, do you have to bypass the fuel filter/bypass the piston lift pump/install an airdog or FASS/upgrade the fuel pickup/upgrade the fuel lines/etc to make big power?
Just curious, because it seems like you have to do this with a VE to make "big" power.
Old Dec 11, 2010 | 05:34 PM
cedardiesel's Avatar
Yea the 1/2 line from the airdog is fed straight to the ip.
Old Dec 11, 2010 | 07:27 PM
The_Head's Avatar
No that's not it. What I want to know if it's possible to make good power (500 whp) on all stock stuff... stock lift pump (would get a new one of course), stock fuel lines, stock tank pickup, etc.
I am kind of wondering what else would be involved if I decided to do a conversion.
Old Dec 11, 2010 | 07:29 PM
Tate's Avatar
A 2nd gen lift pump will keep it supplied past 500hp.
Old Dec 11, 2010 | 08:46 PM
Subliminal's Avatar
...which is the opposite of what he's asking.
I kid, I kid!
Old Dec 11, 2010 | 09:08 PM
The_Head's Avatar
you kidder you!
Like I said, I was just curious. I would hate to swap in a P-pump engine and then have to do a bunch of other stuff.
Old Dec 11, 2010 | 10:05 PM
RonA's Avatar
I run a piston pump on my p-pumped first gen. It does fine up to 700 hp. Above that the pressure starts to drop. I added a FASS HPFP and plumbed it into the front of the pump. I only use it when i need it and it seems to work well. The two will hold 40psi at over 900hp. Simple install, but probably not needed with just a 12mm pump.
Old Dec 12, 2010 | 12:55 AM
Oh I'm sorry and with a 180 or 215 pump I see it being very Possible with stock fuel system just watch pressures close don't want that rack to hang very scary feeling been there done that in our race truck.....
12valve
35
Oct 19, 2016 02:42 AM
6 2 Carl
Nov 27, 2010 09:55 AM
M1Lover
Feb 16, 2010 09:00 PM
wcialrlter
Apr 17, 2008 05:51 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
