Another Oil Pressure Question?
Old 06-25-2007, 08:36 PM
DISLSMOKE's Avatar
My stock guage will read in the middle when its cold. When its hot it will read 2 lines from low. What do these lines mean 10psi per line? Or should I just plumb in a mechanical guage from the filter housing and be done with it? I'm worried about pressure getting too low . Thanks.
Old 06-26-2007, 06:51 AM
gomerpile's Avatar
well what i did was i just intalled a gauge directly on top of the filter, and i check it every now and then
Old 06-26-2007, 02:24 PM
DISLSMOKE's Avatar
You just screwed the guage right in? no tubing or nothing. Didn't run it in the cab? Do you see a difference in the guage on the filter to the one in the cab?
Sorry for all the ?
Old 06-26-2007, 03:09 PM
It means you have some oil pressure.
The stock gauge is pretty vague. If it bothers you plumb in a real gauge.
Old 06-27-2007, 09:10 AM
DISLSMOKE's Avatar
Thanks Wanna, I have new cheapo sunpro guages that I was going to use on my '86 gasser. At least now I have a use for them. Where is the water temp sender on the cummins? Might as well plumb that up too. Sorry, where is the best place to plumb the oil guage? From the stock sensor location or the filter housing?
Old 06-27-2007, 05:55 PM
Factory temp sender is toward the back of the head on the driver's side, most guys put their aftermarket probe near the thermostat housing (big pipe plug there).
Put the oil pressure wherever you feel like.
leeboy
03-26-2008 11:08 PM
Power Ram 250 C
02-20-2007 11:08 AM
Jezzhuntin
08-25-2006 02:51 PM
CIN'S DODGE
16
12-05-2005 04:14 PM
Quick Reply: Another Oil Pressure Question?
