another highidle ?
Old 11-08-2008, 05:21 PM
HecTiK's Avatar
another highidle ?
I went to the dealer to have them enable my high idle feature. They told me it would only work with an auto though. Would it work on my 5spd? I think it would but I didn't feel like arguing with them. Thanks, Andrew
Old 11-08-2008, 05:41 PM
johnh's Avatar
i don't know about your truck, but mine works.
the build date on mine is june 2000
Old 11-08-2008, 09:13 PM
DRD
DRD's Avatar
I've got it enabled along with the 3 cylinder idle, I think it was all part of the same program they flashed? At any rate my trucks a 5 speed. As long as your parking brake is on and it's cold enough it'll idle up.
Old 11-08-2008, 11:49 PM
HecTiK's Avatar
They said the flash was for an auto, although I looked at the tech bulliten they gave me, and it said it had to be in park or neutral, so it sounds like it'd work either way. Should I just tell them to do it anyways?
Old 11-09-2008, 06:43 AM
bentwings's Avatar
If you can find someone with a Smarty nearby you can enable it yourself. I've done a few with mine and all work great when it is cold. You can hear it a block away on 3 cyl. haha
Old 11-09-2008, 08:17 AM
nickg's Avatar
I had the dealer last year enable mine, I've yet to have it work, and trust me Edmonton gets COLD. I'm not sure if they didnt do it right or I have a TPS problem, The TSB says it will engage when certain parameters are met, I have adjusted my TPS and I've yet to see it read 0% (checked with snap-on scanner) so until I fiqure out the TPS thing I dont know if the dealer did it right or not. (cost me 100$ to have them do it and they claimed it was not possible on a 98-02 24V. Then I presented the TSB and then they did it, go fiqure huh)
anyone in EDMONTON got a smarty?????
Old 11-10-2008, 06:48 AM
RacerRon's Avatar
After they flash it, they also have to enable the high idle / 3cylinder feature with the DRB scanner. It is disabled by default. Also, if you plug your truck in, it probably will not be cold enough to engage. This is half the reason I bought the Quad Adrenaline, so I can make fast idle work any time I want it.
Old 11-10-2008, 01:11 PM
91rangerturbo's Avatar
Read this thread on high idle. very informative.
https://www.dieseltruckresource.com/...=185200&page=5
Old 11-12-2008, 07:31 PM
DmaxDouglass's Avatar
location
Does anyone know the location of the intake air temp sensor. That is in a 2000 dodge.
Thanks,
Robert
Old 11-14-2008, 12:01 AM
RacerRon's Avatar
Thanks,
Robert
It is on the side of the head almost under the cowl. Look at the top of the fuel filter.....it is a little farther back and right next to the MAP sensor.
NOTSTK
10-20-2007 07:52 PM
Ls1z28fbody
11-27-2006 08:03 PM
snowrodeo
10-09-2006 09:11 AM
Jezzhuntin
08-25-2006 02:51 PM
Quick Reply: another highidle ?
