Another Damper Gone??
Old 11-12-2009, 04:59 PM
Brian Lent's Avatar
I had my first stock damper go around 100k and bought another stock one for $5 off ebay that was like new with low miles. Yesterday I was towing about 14k from pa thru md and kept the revs betwee 2000 and 3500rpm. Went out today and started it and heard some weird noise so looked and the rubber is sticking out and wobbling again. I ordered a fluidampr that will be here tomorrow. I was wondering how many others had a similar problem. I only got about 43k on this one. Also is the pinning absolutley necessary with the fluidampr?
Old 11-12-2009, 06:46 PM
Howling's Avatar
ATI should have their damper out in the next month.
Old 11-12-2009, 07:08 PM
Brian Lent's Avatar
I heard you can't use the stock fan with theirs. Anyway I already ordered a fluidampr. I see you have the tnt-r, did you ever have a problem like this?
Old 11-13-2009, 06:19 AM
elirandolph's Avatar
Are you going to pin it?
Old 11-13-2009, 07:55 AM
Brian Lent's Avatar
I am going to read the directions, someone on another site said that it is only needed above 4k rpm so I will see what it says. As of right now I don't plan on it.
Old 11-14-2009, 02:34 AM
jlibert's Avatar
I turned 4000-4200 rpm a number of times--no pin-- without any issues. Use red loctite on new cummins bolts.
Old 11-14-2009, 07:39 AM
Brian Lent's Avatar
Yeah I put her on yesterday and used the red permatex and tqed to 125 ft lbs. The directions say over 3500 to pin it but I never go over 3500 so I'm good. If I get into sledpulling then maybe I will pin it. Thanks guys for the help.
Old 11-14-2009, 07:54 AM
Topper's Avatar
How often do these go bad? What are the signs? I have had a funny vibration in my truck for a while but never check my dampener. I have 105 thou on her.
Topper
Old 11-14-2009, 08:54 PM
Brian Lent's Avatar
You can hear it and look and seerubber hanging out from the damper
Old 11-15-2009, 08:11 AM
J Lent's Avatar
Now let me tell the story about Brian Lent. He pulls out from a stop sign with his foot in the floorboard everywhere/every time. He usually keeps rpms over 2200 even when pulling through a drive through at Burger King. Sometimes he pulls past the pickup window because he popped the clutch too fast with the revs up. The truck tows 14k#-18k# on a regular basis & usually 10-30mph above speed limit depending on where the cops are sitting. The passenger side "Oh ****" handle is broke because I have been scared for my life quite a few times. Do you guys think he should pin his damper?
Old 11-15-2009, 08:25 AM
Brian Lent's Avatar
This is harrassment.
Old 11-15-2009, 10:11 AM
Sounds like it!
Old 11-15-2009, 11:13 AM
pullin hard's Avatar
i would pin it, and then weld it too.not sure if that will be enough though.
maybe remove 2 or three spark plugs!!!!!!
Old 11-15-2009, 04:38 PM
J Lent's Avatar
Now it is sounding more like it.
arroyojim
48
09-09-2016 09:43 AM
cbrahs
11-01-2011 11:00 AM
TAMU
05-27-2009 06:34 PM
TAMU
04-27-2009 11:26 AM
3500Dooly
23
06-08-2006 10:21 PM
Quick Reply: Another Damper Gone??
