another Crazzy Larry ?
I called bully they went on & on about proprietary information. That was not what I wanted to here. Also promised to send me dyno info & I never received it. Thanks for your guys help any more info would be appreciated. doug
According to BullyDog, the standard BDDL does 30hp worth of pressure on the 90hp Performance setting and 50hp worth of pressure on the 130hp Extreme setting. Justin(?) at BullyDog had said when the Crazy Larry first came out that they were getting as much power via pressure as the truck would give since pressure runs cooler than duration..….which if accurate would put it in line with BigBlueDodge's comments, "You probably don't want to know……." Crazy Larry is fun and makes a ton of power, but I'm pretty sure they never intended it to be a daily driver program. If I remember correctly, doesn't the instructions that come with it say that setting is "For Track use only" or "For Racing Applications Only" or "For Improving 1/4 Mile Times" or something like that?
HeberRam
Mar 30, 2007 05:37 PM
Snojumper
34
Mar 18, 2007 12:27 PM
