amsoil /traneyfluid
amsoil /traneyfluid
wanting to change to amsoil traney fluid .having to drop traney pan to replace1st to second presure selonoide an posible v/b.any sugestons on any thing i might need to check on.also is a wick traney filter ok or should i use stock?sotex
I'd skip the Amsoil tranny fluid as you'd be wasting money dumping it every 25 - 30k, which is about the length of time you should be going between dropping the pan, changing the filter, and replacing the fluid that came out. Just buy some Mopar ATF4+ from the dealer or get some Valvoline ATF4+ from Autozone, it'll be fine.
As for the trans filter I used Mopar as I could not buy one at Napa, they told me my trans was not listed in there book. As for the ATF I used Amsoil and like that its 100% synthetic. FYI Mopar ATF is made from dino group III base stock.
traney fluid
startrted runing amsoil a while back in my o4 motor .oil analysers i have used showed good results .very hot in this part of the country amsoil claming to run 50 degres cooler. so ma be worth a trie. any one heard of this. also changing fluid 25 to30 thousand miles is somthing i may not be wiling to do so ofton .seeing i only toe 16 foot trailer with4 four whelers.sotex
Spooler
28
12-26-2009 10:16 AM
czkid
10-18-2007 07:38 PM
OH Sick
25
02-27-2007 12:39 PM
