Amsoil air filter - yea / nay
Old 04-24-2011, 12:27 PM
Polarlys's Avatar
I have an '06 5.9 megacab, Auto trans. I have used the amsoil air filter for about 30k. It is the re-usable type and I check it frequently and clean it often. I'm not in dusty conditions except for while on the road from time to time. Like last month ( March ) we spend a lot of time in the Florida everglades on some pretty dusty roads. Other than that mostly normal driving conditions. It seems that whenever I check I find the flo-meter on the filter housing indicating yellow. My question is: Is the amsoil filter too restrictive for good air flow into our engines. Would I be better going to a different filter. I like amsoil products and do like the fact that it is cleanable and re-usable but I also don't want to starve my engine for good air flow. Would appreciate hearing opinions on the re-usable filer elements.
HappY EasteR to all,
Old 04-24-2011, 01:59 PM
Danderson's Avatar
I used one for a short time when they came out. My particular one slid around in the airbox,so I returned to a stock one. The new NAPA/Wix 9946 is hard to beat. I did the www.psmdiesel.com. airbox mod years ago and no more Filterminder movement at all.
Old 04-24-2011, 05:24 PM
wiskeyVI's Avatar
Mine started to not flow well very soon after I put it in. My indicater kept drawing down.
AMSOIL offered to replace it, but I wasn't impressed enough to take the time with it.
The new HD Dodge factory one works great for me.
Old 04-24-2011, 05:31 PM
torquefan's Avatar
If it is pulling down the minder, it is restricting airflow somewhat. It can be a real balancing act between good airflow and good filtration. It's hard to find a filter that's a given size that improves on both of these features.
Old 04-24-2011, 07:30 PM
cdennyb's Avatar
Location: In Oroville, Ca., same house for past 46 yrs!
I have a reuseable K & N and have cleaned it at least once every 20K miles if not a bit sooner. I hit a dusty road now and again and it sure seems to trap the dust. I like it.
So..
Vote +1 for yea.
Old 04-24-2011, 08:17 PM
Polarlys's Avatar
I've been reading about the new generation of air filters from Dodge, if I remember correctly they are larger and seem to work well. May try then or go NAPA. Have to think on it for a bit. I like the cleanable element but if it's to restrictive that's not good. So we'll have to see.
thanx all
Old 04-24-2011, 09:34 PM
rockcrawler304's Avatar
I have the Amsoil EAA189 cleanable dry filter. I could easily pull the minder down all the way with the stock air filter. Ever since putting in the Amsoil I cannot pull down the filter minder. I clean it often (about every 5 to 10k miles) because I live and drive in very dusty conditions living in the desert southwest. Every time I clean it I check for dust post filter and the tube is always spotless. Or should I say Dust less!!
Old 04-25-2011, 08:16 AM
Polarlys's Avatar
Mine is always clean beyond the filter also. I have no complaint with the filter. I do not live in dusty conditions like the desert SW but occassionally I do find myself driving in them. Most of my driving is light and local. I do to my trailer when we travel but other than the towing my driving is on the light side. I think I've read here where the filters for the newer 6.7's will fit and is a larger element. Are they working well ?????
Old 04-25-2011, 03:11 PM
If I ever got rid of mine I would go back to another paper filter that is actually twice as deep as our stock one. I know the part number has been posted up here. A little searching will find it pretty quick. I hear it does a great job.
EDIT: Here is the part number 53034249AA
And here is some good reading about it plus a few others all in one thread!
https://www.dieseltruckresource.com/...a-t263453.html
Old 04-26-2011, 02:38 PM
DBLR's Avatar
I have pulled the filter minder down into the Red with new Fleetguard air filters with a few WOT thus in plain words the filter minder is more or less a Joke and not 100% accurate.
Old 04-26-2011, 03:48 PM
Polarlys's Avatar
I just called Amsoil tech information. They told me that it is the result of a design flaw in the 5.9 filter box. ( ie. passing the buck I think) but my problem is a known issue. They sent me information on how to return the filter to them for a refund. They do not have a replacement. So I get the refund and purchase a Mopar or NAPA filter I guess and see if there is any improvement.
I appreciate all the information out there from this forum. Thanks all
GCSS
13
06-04-2009 07:02 AM
czkid
10-18-2007 07:38 PM
65pacecar
30
08-27-2007 07:47 PM
ouchman
04-05-2004 11:17 AM
Quick Reply: Amsoil air filter - yea / nay
