Amazed at 8 PSI FP towing!
Old 05-18-2008, 05:30 PM
Roperteacher's Avatar
Just had the FP gauge installed this past week. 11 PSI Idle, 10 cruising down the freeway. Today I towed my Large LQ horse trailer for the first time and It only pulled it down to 8 PSI up some pretty steep grades in 5th gear 2000-2100 RPM's. I would have thought it would have pulled it down more? I'm a pretty happy camper! Still a little clatter under load until I reach speed but that must be a quirk of my dodge...
Old 05-18-2008, 06:02 PM
Syndicate's Avatar
mine clatters too until the TC locks up under med throttle input.
Old 05-18-2008, 08:47 PM
Yea, I posted on here couple times about the clatter. Mine is a 6 speed. Mine does it until I reach 65 MPH or so then seems to quiet down. Or any time I let off the throttle slightly it goes away!
Old 05-18-2008, 11:36 PM
Spooler's Avatar
Fuel additives will make it clatter if you are running any. That is why I stopped using them.
Old 05-19-2008, 10:11 AM
Thanks spooler. I am caught between a rock and a hard place on that one! LOLOL I want to add lubricity but don't want the clatter either. I need to make a run up the central coast this weekend so will not use the additives on my next 2 fill ups and see what happens!
lovinCTD59
12-23-2008 11:10 AM
tomd
01-13-2007 08:26 AM
wana12v
10-04-2005 05:34 PM
csramsey640
09-27-2005 11:28 AM
stevesmitty
03-21-2005 03:38 PM
Quick Reply: Amazed at 8 PSI FP towing!
