I am doing GWK are 12mm washers ok?
Old 04-07-2009, 07:41 PM
SilverHoss99's Avatar
I had read that 12mm work perfect is there any truth to that?
Old 04-08-2009, 07:15 AM
mt72916's Avatar
what is GWK?
what is GWK?
Old 04-08-2009, 01:34 PM
wcbcruzer's Avatar
I used two 7/16" washers. They were both very close to 0.91" in diameter and had an inner hole diameter closer to 1/2". Both were 0.074"-0.076" thick. I found them to be a better match for this job than the 3/8" washers. I took my digital caliper into Ace Hardware and measured a lot of washers until I found two that were almost identical in measurement and spec. I think finding two identical washers is the key for this mod to work right. There's lots of variation between the same size washers.
When installing the washers I drilled the holes out to the point that they fit snuggly around the spring retainer nut. Then I added a tiny bit of super glue to hold the washer to the retainer nut. Otherwise, it kept on getting misaligned when I tried to put it on and it would touch the outer idle spring.
That setup has been working well for me. I didn't even have to adjust my idle afterwards. Knock on wood.
I gotta warn you though that it seems like the 97-98 12v's had more issues with getting the mod to work right.
rootremblay
05-31-2007 09:07 PM
inline6359
09-15-2006 12:41 PM
lonewolf42262
06-24-2006 07:47 PM
Underpsi
04-05-2006 08:35 PM
cnvrt2cummins
04-03-2006 01:26 AM
Quick Reply: I am doing GWK are 12mm washers ok?
