Alternative Guage mounting
I have not seen ANYTHING about putting guages where the ashtray is? is there a reason no one has a couple of pod's to go there? This would be considerably better for viewing said guages than to the right of the stereo...
just a thought,
-Tim
just a thought,
-Tim
I put one in the cubby hole beside the radio and it worked great. Geno's sells the plate that goes in there (@ $7.00) but it looks kind of goofy. I used it as a template and built one from metal and used fiberglass bondo to build it up so it looks stock. I also mounted the gauge inside a 45 degree bezel. Looks nice.
I agree that inside that cubby is a good spot, but I use that to hold my cell phone! :P... What I want is a gauge pod like the 03+ have, right under the overhead console, and right above the rearview mirror. I'm not sure there's enough room on the 02 and older but it's still thought .
I wouldn't mind seeing a gauge pod for the ashtray, but it is a little far down to look to see what's going on with the gauges.
I did sacrifice a gauge pod, but one could just glass one up if they were a little more ambitious. I bought a column mount pod and was planning to use that, but it blocked the stock instrument cluster more than I liked. Rather than deal with returning it, I cannibalized it for my ashtray mount. Best decision I ever made...
That is rather visible, very impressive, good work!
Does anyone else have the limp ash tray mod? mine keeps opening up everytime I hit a bump , it was the same way on the other trucks I test drove as well, so I'm just assuming at this point it's fairly common ... Do you have any problems with the ashtray opening all the time with the weight of the pod/gauge there?
Utundra
04-15-2009 06:14 PM
Dynocon
24
11-16-2008 06:32 PM
bigragu
05-06-2006 10:05 AM
