allison automatic swap anyone?
Old 08-11-2007, 11:24 PM
banks twinram's Avatar
has anyone in here ever heard of somebody swapping the dodge auto for an allison with overdrive? i am in the process of gathering stuff to do another ford cummins 5.9 swap into a 1/2 ton and i would really like to use an allison auto with overdrive. alredy have the engine, radiator, motor mounts. just wondering about the allison. i know they use them in small freightliners and kenworths. hopefully one that has no electronic control to keep it simple.
Old 08-11-2007, 11:50 PM
displacedtexan's Avatar
Check this thread out.
https://www.dieseltruckresource.com/...d.php?t=123026
Old 08-12-2007, 10:05 AM
logskidder's Avatar
You could use a 545.
Old 08-12-2007, 10:09 AM
i was looking up info on the 545 using google and stuff. still trying to figure out if there are any electronics that are needed. less is better
Old 08-12-2007, 10:11 AM
will the bellhousing off an 8.3 fit on a 5.9?
Old 08-12-2007, 08:54 PM
logskidder's Avatar
The only electronics are for the speed sensor........I would'nt put one behind a 8.3. Have you thought about using a 47 RH??
Old 08-12-2007, 09:03 PM
logskidder's Avatar
Just reread your post.....The bell for a 8.3 may bolt on to a 5.9, but the 8.3 uses a way bigger flywheel/flex plate and starter.
Old 08-12-2007, 09:11 PM
XLR8R's Avatar
Do you think a 47 is better than a 545?
Old 08-12-2007, 09:17 PM
jd4440's Avatar
the bell housing can be found on school bus with 5.9 which the 545 comes out of along with flex plate starter and tc again as said no eletronics but speed sensor cable shifted but the bell is a sae bell so it can be found else where i forgot which sae number it is though i have a couple i would have to look again
Old 08-12-2007, 11:46 PM
ill have to go school bus shopping to find the stuff i need. thanks.
Old 08-12-2007, 11:52 PM
do u think i can find an air starter for a 5.9 that will fit with an allison
?? that would be cool imo. just pull an ingersoll around with me everywhere i go.
EMD-RUN8
12-14-2009 11:22 PM
MDLP412
11-04-2008 06:00 PM
ontarget87
03-13-2008 10:08 AM
johndeer
05-03-2005 01:58 PM
scottmn1
12-26-2003 11:20 PM
Quick Reply: allison automatic swap anyone?
