AirDog150 users..what fp are you seeing?
Old 01-21-2008, 08:02 PM
SuperDave4x4's Avatar
What kind of FP are yall seeing with the AirDog150??? Also are yall seeing a constant/steady FP?
I can't get a steady FP at all. It varies from 12.5 to 19. It just depends on what the pump wants to do that day. Also the FP is not steady. It will build up slowly to 19spi and drop back down to 15 or 12-12.5, but it usually drops to 15.
Old 01-21-2008, 08:09 PM
J Lent's Avatar
Steady at 16psi on 2 gauges.
Old 01-21-2008, 09:27 PM
Well ***...why am I seeing this crazy crap? It was doing 21psi when I installed it and almost 2 days later is was doing this crazy stuff.
Any other AirDog users out there?
Old 01-21-2008, 10:04 PM
J Lent's Avatar
Do you have a isolator installed?
Old 01-22-2008, 07:42 AM
jp8819's Avatar
MIne stays steady at 14.5 to 15 on fp 100, Have you checked all your connections and also with another guage to be sure sending unit is not going bad.
Old 01-22-2008, 11:34 AM
xtoyz17's Avatar
Have you verified the gauge isn't malfunctioning?
Old 01-22-2008, 07:55 PM
I installed a isolator a couple of days after having the AirDog installed because my gauge was doing this. http://video.competitiondiesel.com/v...18015f6af0.htm After I installed the isolator the needle quit vibrating back and forth rapidly, but I'm still seeing the FP rise and drop.
Today my FP sat right on 17psi, but this afternoon it began to rise and drop just like it used too. I have not tested my gauge, but my buddy down the street has a spare I'm going to install.
When I first installed the AirDog it went straight to 21psi and stayed there, but 2 days later it started doing the crazy stuff
Old 01-23-2008, 09:06 AM
Anybody have any comments on the video? Bad gauge?
Old 01-23-2008, 09:14 AM
xtoyz17's Avatar
Sure looks like a bad one to me, do you have a snubber installed?
Old 01-23-2008, 09:23 AM
J Lent's Avatar
Are you sure that you got all the air out of the line going from the isolator to the gauge, my gauge did that & it was air in the line.
Old 01-25-2008, 11:55 AM
How do I remove all the air from the isolator to the gauge?
Also I don't have a "snubber".
Old 01-25-2008, 12:16 PM
J Lent's Avatar
You gotta take the fitting off the isolator, hold down on the diaphram & fill it up with antifreeze. Reinstall the line, Then crack the line at the gauge & bump your starter to cycle the pump. Tighten the line after the bubbles are out. Repeat the process until no bubbles are present.
Old 01-27-2008, 08:03 PM
OK I see. I'll give that a try, but my gauge was doing all the crazy stuff before and after the isolator install. The video above is when I was running no isolator.
HecTiK
09-15-2009 12:42 AM
Blake Clark
09-10-2009 08:20 AM
jaredb900rr
23
01-28-2009 10:08 AM
TNLoneWolf
17
02-21-2008 06:22 AM
Bswope
02-10-2008 08:02 PM
Quick Reply: AirDog150 users..what fp are you seeing?
