Airdog fuel lines cracking (Pics)
we i have had my airdog system for about 2 years or so now and i love it except i noticed this the other day is that some of the lines are starting to dry rot or crack not sure if i should be worried or not. anyone else have this issue.
Funny, I just replied to another post and mentioned this, Mine had less time than yours but I pumped a lot of fuel thru it, Mine was not cracked as bad, and it seemed worse under hood, a long time ago I contacted Pureflow about it, even sent them a sample, was told that they were only aware of issues when installed on a duramax, beacuse the line was so close to the block, and they fiqured it was heat induced, I replaced mine with bio-compatable stuff from Vulcan, and its seen twice the use my blue hose did, and no cracks of any kind, when I did mine I did not order enough hose, so I kept the blue from the ad to the tank, I was under there the other day and guess what....its full of tiny cracks! so that eliminates the engine bay heat theory
Less than 2 years on mine and they are cracked up as well. I only noticed it in the engine bay. Don't the push lock fittings need to be removed and put in the freezer to slip the new hose on? What a pita, plus the fittings are way soft and need to be wrenched on very carefully.
This problem has got to be very common, people have probably just not noticed yet.
wow so i guess it is common then. i cant really get those bends any better i have tried a few diff routs with the hose and this seems to be the best.
has anyone actually had them start to seep or actually blow out and leak fuel. they seem to be just surface cracks but its still scary thinkin if it does bust you are dead in the water.
kdbvulcan
20
12-06-2008 04:34 PM
