Aircraft Mechanic Needs Help!!
Old 11-18-2006, 10:45 PM
CANADAIR's Avatar
Hello All,
Need some help, or a lot of help, I think my injection pump is gone. Starting my 1997 cummins is intermittent, all fuel lines are good, changed the lift pump, no help. There is fuel getting to the injection pump, and no fuel coming out at times. When the truck starts, it runs like a champ. Scared to think its the injection pump, but that's my next fix, unless you guys have a better idea.
Best regards,
Rich
Old 11-18-2006, 10:59 PM
clutch1's Avatar
When you say intermitten how often? Like yesterday and not today or 5min ago and not now. You mean there is no fuel coming out of the inj. lines right.
As you probably know these pumps hardly ever go out. Good luck.
Old 11-18-2006, 11:05 PM
ratsun's Avatar
Originally Posted by CANADAIR
Hello All,
Best regards,
Rich
This leads me to believe it is in fact not your pump that is giving you your trouble. Have you checked you shut down solenoid? Where are you located?
Old 11-18-2006, 11:56 PM
kawi600's Avatar
You might have air leaking in someplace. First thing Id do is search for info on adding a fuel pressure gauge. Then you can see some of whats going on.
Youd need a needle valve with 1/8NPT threads, some plastic tubing and a pressure gauge for mounting inside the cab. You can drill and tap the banjo bolt on the injector pump inlet for and put the needle valve in there. Use it to damp the pulses from the lift pump. you should see around 25psi at idle and 30-35 at 2000rpm no load I think.
That solenoid check is a good idea. check to make sure it moves smoothly, and check the adjustment.
Old 11-19-2006, 09:57 AM
CANADAIR's Avatar
It Was The Fuel Shutdown Solenoid!!!!!! Thank You Ratsun So Very Much, And The Rest Of You For Some Good Input.
Old 11-19-2006, 11:00 PM
ratsun's Avatar
Glad I could help out, as many have done for me in the past on this wonderful forum.
Old 11-20-2006, 09:40 AM
b.lee's Avatar
yea this website rocks don't it canadair ?!?!
it saved me a good amount of cash already!
upersleder
01-28-2007 05:00 PM
Mexstan
06-29-2006 08:27 PM
converteddzlr
04-03-2006 10:16 PM
ddestruel
03-25-2006 06:50 PM
jj3500
05-30-2005 05:35 PM
Quick Reply: Aircraft Mechanic Needs Help!!
