air only blows out the front vents??
Old 09-07-2011, 02:17 PM
luke03cr's Avatar
on my 03 ctd i am only getting air to come out of the front vents of the dash. my blower speed **** works fine and my blend controls 4 duel climate zone work fine as well. i can switch it from hot 2 cold no prob. But my **** that controls where the air blows from is nt working?? i need this air 2 blow on defrost so when it gets 2 humid when it rains, i can clear the windshield. so whats broken/needs replaced and how 2 fix's. Heck even if i can jerry rig it to blow on defrost all the time wld b fine 4 now. thanx guys.
Old 09-07-2011, 03:15 PM
Dr.Dizzle's Avatar
It sounds as if you have the typical blend or mode door breakage in the heater plenum box. I have attached a link to the Heater Treater website that provides the answers as to which door(s) require replacement. They also have the heavy duty upgraded parts that you will need as well. I recommend you replace all of the doors (blend and mode) at this time.
http://www.heatertreater.net/Ram%2002-08%20Listing.html
Old 09-07-2011, 11:10 PM
jhenson's Avatar
^^^^^ x2. You won't regret it !!!
Old 09-08-2011, 01:18 PM
Move'n Up's Avatar
Heater Treater is the way to go.
I had to replace my broken Recirculator door last summer.
Old 09-08-2011, 05:59 PM
Spooler's Avatar
Blend door is broken or Blend door motor is inop more than likely.
Old 10-21-2011, 09:56 PM
MoparMan1962's Avatar
Thanks Dr.Dizzle for the link to Heater Treater. I'm happy to see they make it appear to be pretty straight forward and it won't break the bank. I was considering taking it to the dealer prior to seeing the video's. Thankfully now I won't need to!
mikeg135
04-28-2014 11:26 PM
freshmeat
05-12-2010 12:38 PM
hognutz
09-15-2009 06:53 PM
caburnside
16
12-01-2008 07:04 PM
bobem12
06-17-2008 12:14 AM
Quick Reply: air only blows out the front vents??
