PDA
View Full Version : air intake
dodgy
12-28-2003, 05:45 PM
air intake!!!!!!!!!!!!!!!!!!!!!!!! With so many on the market who knows? I have heard of many people making one out of the existing stock filter system. I wonder if they are a difference in air pressure compared to aftermarket? Any takers? I'm thinking of doing the same. Fabrication is of the minimum.
Mark Craig
12-30-2003, 08:32 AM
Dodgy,
We are a Pro Guard 7 only distributor, we used to have oiled foam because it stopped the dirt and flowed more than stock paper. Now that Pro Guard 7 is available we only distribute it as it's flows more than foam but per the manufacturers specs stops as much dirt as factory paper, plus it's washable and is a long term cost saver. The PG7 is available as a drop in OEM replacement and as an intake system that's very easy to install, three bolts and your done. Lots more air gets you lower EGT's and better turbo spool up performance too. Call us if you have any questions etc.
Mark @ DPPI
BADBOWTIE
01-01-2004, 07:26 AM
I went with the Ram Air 3. I can tell you that I did see cooler exhaust temps and I am very happy with the slight increase in midrange throttle response.
Jason
tcb
01-02-2004, 11:08 AM
Scotty III by far the best. may not be the sharpest looking but funnels the air quite nicely.
