Air Horns
Old 08-15-2009, 11:00 AM
Blackedout1ton's Avatar
Air Horns
Looking for pictures and suggestions on where to mount a pull chain for my air horns and my air tank. rather it not in the bed.
thanks,
Old 08-15-2009, 01:23 PM
Asher's Avatar
I got a 5 liter tank to fit inside the front fender well, it's dead space and hidden very well. It's tight getting the liner back in place and a remote drain valve is a must, but it is completely out of the way. Another way to get more air supply in little spaces is to lenghten your air lines as much as possible.
Old 08-15-2009, 06:10 PM
bekim's Avatar
My tank and Viair compressor are on the outside of the framerail passenger side. I think the pics are in my gallery
Mike
Old 08-16-2009, 10:23 AM
thanx for the input guys, im gunna mess with it today. my family owns a used truck dealer and we dismantle rigs so i should be able to find a good tank
Old 08-16-2009, 01:03 PM
TexasCTD's Avatar
Mike
Mike, I like your set up. Did you buy it as a package somewhere? Or piecemeal it?
Old 08-22-2009, 05:11 PM
im looking for a good place to mount a pull cord (manual valve horns came off a western star)
Old 08-22-2009, 09:50 PM
cbrahs's Avatar
mounted my tanks in the place of the spare tire
bought a pull valve off a freightliner and mounted it behind the knee bolster.
ran bulkhead fittings thru the firewall to the pull valve
mounted horns to the cross members under the bed
Old 08-23-2009, 03:25 PM
bekim's Avatar
Bought the package from Siege Engineering on Ebay about 2 years ago. Tank, compressor, 1/2" air valve, relay, wiring, guage, tubing and
185 psi switch. The system is wired into the factory horn. Turned the chirp on lock/unlock off for obvious reasons. The system is LOUDER than sh*t! It scares the bjesus outta people!
Post some pics when you get the system in...and thanks for the compliment!
Cheers
Mike
Old 08-23-2009, 04:06 PM
thanx for the pix. i hsve been building my system from truck parts (family dimantles rigs) but i think im gunna end goin with solenoids
Asher
10-27-2007 09:50 AM
Mechanos
09-24-2006 10:22 PM
carcrz
09-17-2006 02:22 PM
DF5152
10-30-2003 05:11 PM
Commatoze
10-01-2003 08:06 PM
Quick Reply: Air Horns
