Air Dog,Raptor,Fass? what do I need
Old 01-15-2008, 08:40 PM
Bulldozer's Avatar
Its time to get something done.Which one of these would be the best choice for my mods? I'm going to replace the EZ with the Adrenaline also? Which Airdog system would you go with.I seen Vulcan had a good price on a Fass 95 with a draw straw or bigline kit.But Airdog looks good too. Somebody piece me together a system that I won't have to worry about. THanks
Old 01-15-2008, 09:47 PM
J Lent's Avatar
I've run the Holley blue, Fass 150 & now have the Airdog 150. The Airdog is quietest, smoothest of all & keeps pressure steady at 15psi at idle & wot. The kit comes with a draw straw, 1/2" lines, fittings & harness. Everything needed to install. I would get the Airdog!
Old 01-16-2008, 05:43 AM
Bulldozer's Avatar
Where did you get yours from,I see they have them for sale in DTR here,I need to make sure it comes with draw straw and stuff.By the way did the Fass quit on you?
Old 01-16-2008, 09:51 AM
J Lent's Avatar
Fass didn't quit, just wanted a system with filters & the Airdog is on sale right now. The Airdog comes with Draw tube, 1/2" lines, fittings, "Y" pipe for hooking the return into the fuel filler neck & all hardware, clamps & mounting bracket for installation. I sent you a pm.
Old 01-16-2008, 06:06 PM
Destination's Avatar
does the Airdog systems use a special set of filters or can you cross refernce the numbers and use fleet guard filters?
Old 01-16-2008, 06:54 PM
J Lent's Avatar
Read this http://www.pureflowtechnologies.com/AirDog.htm
Old 01-16-2008, 10:40 PM
Fishin2Deep4U's Avatar
Based on price, the Airdog is the hot ticket right now.
If you want additional filtering and the other claims of the manufacturer, the full system is for you.
If you want to retain the stock filter unit with the WIF light and fuel heater, the Raptor is for you.
Dave
Old 01-17-2008, 12:14 AM
Scott07's Avatar
With my FASS HPFP I get a little over 21psi at idle and no lower than 14-15psi WOT.
Old 01-17-2008, 06:41 AM
J Lent's Avatar
My Airdog is set at 16psi idle & I can't pull it below 14psi wot. This is with 1/2" lines, 1/2" draw tube & box on kill. My fass had 20psi idle, 10psi wot.
quadgoat
10-16-2009 09:25 PM
StevenAg03
08-17-2009 03:18 PM
stealman1
03-22-2009 10:00 AM
ducktruck
20
01-19-2009 05:43 PM
84mphcdt
16
12-19-2007 11:31 AM
Quick Reply: Air Dog,Raptor,Fass? what do I need
