Air Dog owners where to install FP fitting
Old 01-08-2008, 08:57 AM
HOBrian's Avatar
I was just wondering where you guys were installing the fitting for your fuel pressure. I talked to toby and he said to drill and tap the fitting going to the CP3. I am curious what you guys have done. I will be installing the AD 100.
Thanks.
Old 01-08-2008, 09:46 AM
jp8819's Avatar
I have a vp truck but I put it in the line about a 1.5 ft back from where the line goes into the pump and used a tee also am using the newer auto meter electronic guage.
Old 01-08-2008, 10:01 AM
53 willys's Avatar
I used this..http://www.vulcanperformance.com/ser...-Degree/Detail
Old 01-08-2008, 12:05 PM
ptgarcia's Avatar
Mark,
Which adapter do you need to go from the cp3 to that fitting?
Old 01-08-2008, 12:12 PM
53 willys's Avatar
Originally Posted by ptgarcia
Mark,
here you go....
http://www.vulcanperformance.com/ser...08JIC-X/Detail
Old 01-08-2008, 12:17 PM
ptgarcia's Avatar
Thank you! I don't care what everyone else says, you're all right in my book.
Old 01-08-2008, 12:35 PM
53 willys's Avatar
Thanks Pauly
Old 01-08-2008, 01:10 PM
HOBrian's Avatar
Mark, thanks for the link and write up!! Nice job!!!
I think I am going to drill and tap the one that came with the kit. I know that if something does go wrong I have a place to a new one. 17 bucks is a lot for the fitting ($17 includes shipping)
Old 01-08-2008, 01:31 PM
53 willys's Avatar
I understand the shipping part..I ordered the vulcan drawstraw for my install and just ordered it all at once...plus when you drill the one out that AD sends you it makes you have an extra fitting that other wise you would not need with the Vulcan fitting.....either way works great..I just wanted less fittings
Old 01-09-2008, 08:02 AM
HOBrian's Avatar
I am a little confused???? If I were to drill and tap the elbow that came from AD I would have the same fitting that comes from Vulcan... Right????
Old 01-09-2008, 09:07 AM
Hvytrkmech's Avatar
Yes you would, just make sure you have it anchored squarly in a drill press. You can always do the standard install and replace the fitting later?
Tim
Old 01-09-2008, 09:21 AM
53 willys's Avatar
Unless something has changed your AD fitting should look like this....
http://www.vulcanperformance.com/ser...-08-JIC/Detail
if you use a piece like this then you also have to use an additional straight JIC push lock fitting....the one I used is a 90* and a push lock in one fitting...
like I said either way works just fine....
carte89
02-14-2010 12:36 AM
Mexstan
02-09-2010 10:46 PM
trailinone
16
06-19-2009 04:28 PM
herb
07-18-2008 08:25 AM
kev94mx
19
06-15-2007 07:33 PM
Quick Reply: Air Dog owners where to install FP fitting
