Air Bag Install Question??
Old 03-29-2010, 05:47 PM
dspoon's Avatar
I want to add some air bags on my 2500 but heres the problem I have the reese fw hitch the brackets that mount on the frame are on the outside over the axle the air bags have to be mounted on the outside over the axle to.
This means I will have to drill through the hitch bracket to mount the air bag bracket and it would throw it out of line about a half a inch from the mount is this ok?
How are you guys running bags with hitch brackets on the outside of the frame any ideas??
Old 03-29-2010, 06:49 PM
JKM
JKM's Avatar
I just did two sets of airbags just like that , it doesnt cause a problem at all , i drilled through the frame and the hitch bracket and bolted the bag mount on. works fine, no problems at all.
Pm me and i'll give you my phone number if you have any questions.
Jayme.
Old 03-29-2010, 07:46 PM
dspoon's Avatar
Thanks Jayme for the info. just wanted to make sure its ok
Old 03-29-2010, 07:55 PM
OldDodgeOwner's Avatar
I don't know for sure how they mount on the 2nd gens, but I've got a set of Airlift bags on my 06. They mount on the bottom side of the frame, don't interfere with the B&W hitch at all.
Old 03-30-2010, 03:55 PM
JKM
JKM's Avatar
Our second gens mount on the side
Old 03-30-2010, 09:16 PM
skidlyman's Avatar
I just installed airbags too, I was going to take them back off and grind out about a 1/2 inch on the frame side of the top brackets (3 holes each side) but once I used them a couple weeks and re-inspected them they look like they will be OK. Be sure you use spacers in any gaps between brackets and mine needed longer top mounting bolts 3/8"nc x 2"
samfox737
08-25-2014 06:57 PM
Lonepine78
09-25-2013 10:57 AM
justagoodolboy
03-07-2011 08:25 AM
Bad Ramer Jamer
06-14-2008 11:01 PM
PZM123
02-05-2007 06:01 PM
Quick Reply: Air Bag Install Question??
