aftermarket shocks holes wrong size clunking
Old 12-27-2008, 09:58 AM
Pa outlaw's Avatar
how many people bought after market shocks only to have them on a lil while and have a clunking when they go over bumps in the road, i have had rancho, fab techs and super lift shocks on my trucks and they all done it, the bolt hole is too large on the after market shocks, i thought about drilling the shock hole brackets to take a american bolt so the shocks wont do this, anyone else have the same issue? took me a while to figure out it was the shocks making the noise
Old 12-27-2008, 10:22 AM
Igor's Avatar
I had this same issue when i had my superlift bilsteins installed and they started about about 10k. Had about 30k when I took them off. The factory bolts were destroyed, tiny shock bushings were done, etc.
Ordered replacement bushings and they came with the proper bushing sleeve. I rebuilt the bushings myself and installed using new OEM hardware, antisease in the bolts, and dielectric lube (silicone grease) on the bushings. This helped prevent rusting of the OEM bolts to the bushing sleeve and helped keep some moisture out of the bushings and let the stuff slide/work properly.
Another 15k now, no issues. But the shocks are now leaking. So gotta get new shocks.
Tired of buying junk
Old 12-27-2008, 10:55 AM
Pa outlaw's Avatar
You Got To Love It, I Thought About Just Drilling The Holes And Moving To The Size Bolt For The Aftermarket Shocks Because They All Use The Same Size
whosdunit
01-11-2017 01:54 AM
EverydayDiesel
08-19-2007 09:38 AM
1969mach1
04-05-2007 07:47 PM
trik396
12-01-2005 09:21 AM
silverram323
07-28-2003 02:00 PM
Quick Reply: aftermarket shocks holes wrong size clunking
