Aftermarket flex plate?
Old 04-06-2006, 07:37 AM
mooseman's Avatar
How necessary is an aftermarket flex plate with my new DTT. I was told that over 500 hp a flex plate is a must. If the stocker will hold up to an occasional launch and a couple truck pulls I wont worry about it.
What should I do?
I have until Monday to decide while the trans is out.
Thanks Mooseman
Old 04-06-2006, 10:25 AM
joefarmer's Avatar
If twins are ever in your future, it's well worth the piece of mind and assurance. We had a truck run fine at ~415hp with the stock turbo for 6 months with a built DTT and then 2 months after the twins went on (481hp) the stock hub on the flexplate shattered. The plate actually shattered drving down the road after racing a quick TransAm. The TransAm lost and the flexplate did too.
brandon.
Old 04-06-2006, 10:44 AM
paulb's Avatar
What should I do?
Thanks Mooseman
By your sig it looks like you are just over 500hp. If DTT recommended it then I would do it. I have one in mine and I'm glad I did it. Last year I saw three different trucks with broken flex plates. Two 2nd gen's and a 3rd gen.
Paul
Old 04-06-2006, 11:41 AM
gsdog1's Avatar
If you have the cash, I say do it. Heck of a lot less expensive at this stage than later for sure.
Several threads over in the 3rd gen performance section that go into what can happen when if the stocker lets loose.
rangerst
15
02-20-2004 09:50 PM
apache
12-11-2003 01:00 PM
whazzup
08-24-2003 08:21 AM
CR7135
07-14-2003 10:19 PM
Quick Reply: Aftermarket flex plate?
